Building the Neck http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=43915 |
Author: | Mike OMelia [ Sun Aug 03, 2014 7:47 pm ] |
Post subject: | Building the Neck |
I must be doing something wrong, but I'm having a hard time finding a video on neck building from start to finish. I am starting with a 3x4 block of Mahogany,enough for two necks plus blocks. I want to precut the dovetail joints. I do have that neck jig from Luthier Tools, but I'm not confident enough to cut the joint when in the body yet. Building necks for the OLF SJ. Resources appreciated Mike |
Author: | Dave Livermore [ Sun Aug 03, 2014 11:00 pm ] |
Post subject: | Re: Building the Neck |
Charlie Hoffman has a great website full of info on how he does things. I would guess his eoght pages of info on building necks would be helpful. http://www.hoffmanguitars.com/building_a_guitar.htm Good luck Dave |
Author: | Mike OMelia [ Mon Aug 04, 2014 10:29 pm ] |
It's interesting. So little (as far as I can tell) on neck building. There are plenty of carving technique videos. I was hoping for something a bit more comprehensive. Guess I'm nervous about this. |
Author: | Blain [ Tue Aug 05, 2014 7:25 pm ] |
Hey Mike, If you can't find what you're looking for, I'm sure a detailed description of where you are at on the Neck and what your questions are, will get you plenty of help here on the OLF. |
Author: | Mike OMelia [ Wed Aug 06, 2014 8:55 am ] |
Well Blain, I didn't really want to bother folks with this since it is such a big aspect of building. I honestly figured I'd find a "soup to nuts" video somewhere. I even asked John Hall and he has yet to tackle this. I think (like myself) many of us turn to pros who focus on just making necks. But the guy I used to deal with stopped doing it. Honestly, I never thought he much enjoyed what he was doing. Maybe not enough money in it. He did do good work though. Maybe I'm reading that situation wrong. Anyways, that leaves me a point A. Big old 3x4 block of mahogany. Enough for two necks. I have the pattern (OLF-SJ), etc. And the Luthier Tools neck jig (gen 2) for the dovetail joint. I intend to cut the blocks before install since I am not yet confident of doing that after the box is built. So the neck jig is a bit of overkill at the moment, but the end vises and patterns are excellent. Speaking of, I need a 7 deg dovetail bit. I have all the tools. Except rasps and spokeshave. |
Author: | Barry Daniels [ Wed Aug 06, 2014 9:48 am ] |
Get a good book. Benedetto's archtop building book presents a streamlined approach to neck building that I have been using for a few years, even for flattops. |
Author: | George L [ Wed Aug 06, 2014 9:50 am ] |
Mike, Yep, like Barry said. For step-by-step instructions I invariably find myself going back to the Cumpiano/Natelson book. I usually adapt my processes from there, but it helps me understand what needs to be done. Have you searched YouTube for luthier tools neck jig or similar wording? Robbie O'Brien has covered just about everything at this point, so that would be a good place to start. He uses mostly LMI tools, but no matter th jig we're all going for the same geometry. Jon Simpson has some nice videos on his jigs as well. If I had your jig, I'd just make up some test dummies out of scrap wood and practice cutting both parts of the joint. Heck, that's a great jig and the whole point is to make things easier on yourself. What you're proposing is actually harder to accomplish. I'd just practice it a few times, eat a sandwich and ponder what I was doing, practice it a few more times and go for it. That's how I figure stuff out anyway. Yeah, I make mistakes, but it's just wood. |
Author: | Terence Kennedy [ Wed Aug 06, 2014 10:24 am ] |
Here's a little tutorial I did a while back, it 's in this thread. It's for a two part neck but all would apply to a one piece. viewtopic.php?f=10101&t=43068&p=569470&hilit=Neck#p569470 |
Author: | Mike OMelia [ Wed Aug 06, 2014 10:43 am ] |
OK, will do. BTW, how do I practice without cutting a real box? That's my concern. Yes, I can practice on blocks of wood. And I will. Thanks! Mike |
Author: | Mike OMelia [ Wed Aug 06, 2014 10:51 am ] |
BTW, the neck jig document suggests that I use a 1/2" shank dovetail bit. I have several (3) Bosch Colt routers (I love them). One is mounted to that expensive plunge mechanism I bought off the classified forum (same guys make those precision collets). Can I safely use a 1/4" shank dovetail bit? |
Author: | weslewis [ Wed Aug 06, 2014 11:01 am ] |
I cut out my neck blanks to shape accurately, then use a round over bit in a router table to shape the neck, provided the thickness is real close to final thickness very little work is needed, taking small cuts is the key , takes a little practice , I also like using quarter sawn sapele and buy big boards to cut out blanks, available at wood dealers and last board I found at my local woodcraft. |
Author: | Clay S. [ Wed Aug 06, 2014 12:15 pm ] |
A 1/4 inch shank dovetail bit will work if you first cut most of the neck pocket with a straight bit. You can make a larger subbase for your trimmer out of a piece of lexan or plexi (if necessary) to span the neck pocket. |
Author: | jayluthier [ Wed Aug 06, 2014 12:40 pm ] |
I suggest you just make up some practice blanks from Doug Fir or Poplar...cheap investment. Make some necks with that wood. If you mess up, no loss. Nothing teaches you better than just diving in. I suspect that you will find that the learning curve is pretty short. As for routing the dovetail pocket after the box is together, I suggest that that is preferable to fabricating a neck block with the dovetail mortise already cut. Verrrry difficult to align the block when you glue up the sides. Much better to rout the pocket after it's all together. It's only wood...have a go. |
Author: | Mike OMelia [ Wed Aug 06, 2014 1:09 pm ] |
OK, I'm gonna practice. I guess when I get to the point of cutting the pocket, I can ask a lot more questions. |
Author: | James Orr [ Wed Aug 06, 2014 1:35 pm ] |
I really like the sequence in Trevor Gore's "Build" book, but it's broken up throughout the book. Chapters 6, 7, 8, and 9 of Robbie O'Brien's Online Acoustic Guitar Building Course are really good, and sound like what you're looking for. |
